gravitate Posted January 29, 2009 Report Share Posted January 29, 2009 1. ok i just got a new tiny laptop. its a japanese design and like just bigger than my hand. I have downloaded msn live but when i try to sign in I get the error message 'service temporarily unavailable. Please try again later'. i have tried logging in on the msn already that comes with xp but get the same message. yahoo messenger and skype work fine. i tried turning firewall off ets. 2. evertime i turn the machine on it says my wifi is secured and asks for a WEP key which I dont needand get on instantly with any other device for any other device. I have to mess around repairing the connection etc before it works properly. It is not security enabled 3. I try watch you tube and it says i need the latest version of adobe flsh player or java script maybe turned off. how do I enable javascript? Also when i follow links to download flash player i alsays get the same error message 'unable to authenticate installer'. any of these answers would make me so happy. Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted January 30, 2009 Report Share Posted January 30, 2009 What operating system does your computer have?What version of Internet Explorer?Turning off the WEP settings is probably done with a wireless configuration utility for your wireless network card. Quote Link to comment Share on other sites More sharing options...
