[Need Help] Vista & XP network problem
thbdaone
Hi y'all!
I have a small problem. There's a small network of approx 10 PCs I have to configure to make their files & printers accessible to each PC. The PCs running Windows XP work just fine, I've configured them using Network Setup Wizard found in control panel. The workgroup name is: MSHOME, file & printer sharing is turned ON.
On Vista when I open up network and I try to view computers on the network. Nothing shows up, except the gateway. (Note: Workgroup is also MSHOME, same IP range, File & Printer Sharing is turned ON, Network Discovery ON. Well pretty much everything is ON. :) ). When I try to access computers running XP by entering their IP directly it opens up fine. But the problem it's not accessible via Network.
I've tried to disable IPv6, because I've read somewhere that it may cause problem on some switches. Did not work. I've changed the workgroup name and put it back to MSHOME, did not work also.
Could someone help me. Please I'm lost. :(
ok
you need to know the printer ip and that you have installed the
printer on each machine is recommeded
and set up the printer to the ip that you know
and i use the brother utilitly
Brother admistrator Utililty
the program is called BRAdmin Professional 3
it will dectect the printer that is install on the computer
you are using
the printer must be installed on the computer you are using
best to put BRAdmin Professional 3 on your admistator computer
which manage the rest of your network (your main computer)
it will tell what your printer ip
which has been helpful for me when my printer changes it ip
and also you can find out your printer ip go to your router's page
and you should be able to see what all the ips plus your computer
and network computer(s) and printer(s)
i dont know if the switch has a ip of it own which does not appear to be
i have 2 switches connected to the router
