Sound Distorted
samarth1200
Hi!
When I play music in the back ground and run another application in the front like adobe reader or MS word, the music gets distorted and screeches for a couple of seconds and then gets back to normal.
I don't know why it happens .... any ideas??
I had the PSU replaced. I suspect its my HDD. How can i confirm?
Config:
P4 2.8 ghz
Asus P5N- MX
1 Gb ram
250 GB WD HDD
80 GB seagate HDD
  • 3 weeks later...
Judging by the size of your hard drives, I would say they are PATA. If so, you should check if any of the hard drives aren't running in PIO mode. You can do that from Device Manager -> IDE ATA/ATAPI controllers -> Primary IDE channel (and secondary as well) -> Advanced Settings: check each device that reads "Auto Detection" on "Device Type" to have "Ultra DMA Mode X" (where X is a digit) on "Current Transfer Mode".
Let me know how it works. Cheers.
