Network printer problem
GreenMTman
Hi everyone- I just purchased a Dell laptop running Windows Vista Home Premium. I have an older Dell desktop running XP. My Lexmark 8300 All In One printer is connected to the desktop, but was wirelessly networked to my old laptop. I can't get this arrangement to work with my new laptop. I can "see" the printer in my MSHOME network from my laptop, but not vice versa, and naturally I can't print remotely. Thanks...
since you can see the printer in MsHome
got the ip of the printer
and when you go to the printer properties
go to the Ports tab
try Configer Port or Add Port
and use the ip that you got
this a little tricky
working with this
i dont remember how i did it
but i got it working
but there is another way as well
but you can go to your printer ip
but you have to know you user and password
you should fine that in the manual
but that is your setting for the printer that you
want to do special functions
overall you must have your printer install to use the
network if not do the install with networking
good luck
