pegazoo Posted March 4, 2009 Report Share Posted March 4, 2009 Greetings!So. my problem is the next. When i turned on my it's crashed out at the "Vista loading bar" stage. Exactly when my copperhead is blinked out... This problem was with XP too. But after soft or hard reset, or waking up this problem is not there. Only when i switch off and after on. This is the problem in the 99% of the cases. I changed my HDD-s, RAM-s, new power supply on there. I know that is there too many possibilities but i hope this incident is familiar for somebody!Thanks! Peace! Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted March 5, 2009 Report Share Posted March 5, 2009 Welcome to the Windows Forum.Sorry, your description is too vague to help you. What do you mean "crashed out" - BSOD ("blue screen of death")? If so, what was the error code? If you don't have an error code, can you check the Event Viewer for the time when it crashed? Quote Link to comment Share on other sites More sharing options...
pegazoo Posted March 5, 2009 Author Report Share Posted March 5, 2009 Welcome to the Windows Forum.Sorry, your description is too vague to help you. What do you mean "crashed out" - BSOD ("blue screen of death")? If so, what was the error code? If you don't have an error code, can you check the Event Viewer for the time when it crashed?It's just simply stop! When the usb devices blinked, all the system is stopped and nothing more. BTW thanks for helpfully attitude.UPDATE: Yesterday i updated the bios and after for two restarting i didn't exoperienced the crashing so maybe i solved the problem. Tonight i'll test and if it's works i'll post this. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted March 5, 2009 Report Share Posted March 5, 2009 Thank you for the update. If the problem reoccurs, can you try to boot into Safe Mode? Quote Link to comment Share on other sites More sharing options...
Katy Posted March 5, 2009 Report Share Posted March 5, 2009 I had a similar problem a few weeks ago with a bad PATA cable which had a defective contact in one of the slots. You may wanna check that. Also I recommend pulling out and pushing back in any component that lives in socket/slot: memory modules, graphics card(s), various cables etc. That would refresh any possible defective contacts.Let me know how it works. Cheers. Quote Link to comment Share on other sites More sharing options...
pegazoo Posted March 18, 2009 Author Report Share Posted March 18, 2009 Ahh update finally!So the solution was too basics. BIOS UPDATE and the trouble is gone...Thank you very much everybody who want to help!!!!Peace and have a nice day! Quote Link to comment Share on other sites More sharing options...
