inuit-joe Posted June 15, 2009 Report Share Posted June 15, 2009 Ok about 8 days ago i created an ad hoc network, it was all fine.so to days ago i created a new ad hoc network to send my internet to my ps3.but now its says"signal strength: so signal"i dont understandany ideas?you can find a screenshot here: http://img134.imageshack.us/img134/5463/screenshotmnq.pngside notice i apologise for one of the network names, my friend set it upthere both set up the same (the same way i did it a week ago) and they both dont work Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted June 19, 2009 Report Share Posted June 19, 2009 I'm not sure you have to use an ad hoc network to connect your ps3 but that doesn't sound like the issue. Are you able to connect to the wireless using other computers? If so, check to make sure the wireless is turned on on your ps3. If not, make sure the radio is turned on on your Wireless Router. Quote Link to comment Share on other sites More sharing options...
