DeanFX Posted June 27, 2009 Report Share Posted June 27, 2009 I have been using DOS to FTP to my website at work. I have been using it for a while, until not too long ago where I constantly get the following issue:220---------- Welcome to Pure-FTPd [TLS] ----------220-You are user number 1 of 64 allowed.220-Local time is now 16:44. Server port: 21.220-This is a private system - No anonymous login220-IPv6 connections are also welcome on this server.220 You will be disconnected after 10 minutes of inactivity.User (X.com:(none)): X331 User X OK. Password requiredPassword:230-User X has group access to: X230-This server supports FXP transfers230 OK. Current restricted directory is /ftp> dir200 PORT command successful150 Connecting to port 56528> ftp: get :Connection reset by peerftp>I can't CD, List files, nothing. It always resets my connection...Does this have something to do with the computer I am on? or my Host?Let me know if anyone has any answers, or has had this problem before.Thanks in advance!-Dean Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted June 28, 2009 Report Share Posted June 28, 2009 Looks like a problem on the server side.Try if you can access a public FTP site, such as ftp.microsoft.com . Quote Link to comment Share on other sites More sharing options...
DeanFX Posted June 28, 2009 Author Report Share Posted June 28, 2009 Looks like a problem on the server side.Try if you can access a public FTP site, such as ftp.microsoft.com .I get the same error. Quote Link to comment Share on other sites More sharing options...
DeanFX Posted June 28, 2009 Author Report Share Posted June 28, 2009 Just tried on my laptop and it works fine. So it has to be something with my work PC. Quote Link to comment Share on other sites More sharing options...
