Redundant Application copies in system
jaymax
Hello,
Microsoft 2000 and later stores programs in %root%\Program Files\
Now for each user on the system it seems to store copies of the programs [once used] again in
%root%\Documents and Settings\<<user name>>\Application Data\Application\
Are they really necessary, and how can I be rid of them?
Thanks
Do you mean Windows 2000, or Office 2000?
Either way, programs are not copied in %APPDATA%, but as the folder name says, application data are.
If your Windows / Office does that, then something is seriously wrong with your installation. Can you give some examples what is duplicated?
