Amara Posted October 18, 2009 Report Share Posted October 18, 2009 Lately my laptop has been shutting down when on battery power when the battery power is low. The problem is that it does not give me a warning, the usual critical battery warning that is. Also, it does not always show the battery meter in the taskbar even though in power settings I have told it to do so. I'm thinking the two problems are most likely connected, but I'm not sure. I recently replaced my motherboard and was hoping that might fix the problem (although I replaced it for a different reason) and it didn't. I am running windows XP home edition. Thanks!! Quote Link to comment Share on other sites More sharing options...
Amara Posted October 18, 2009 Author Report Share Posted October 18, 2009 Lately my laptop has been shutting down when on battery power when the battery power is low. The problem is that it does not give me a warning, the usual critical battery warning that is. Also, it does not always show the battery meter in the taskbar even though in power settings I have told it to do so. I'm thinking the two problems are most likely connected, but I'm not sure. I recently replaced my motherboard and was hoping that might fix the problem (although I replaced it for a different reason) and it didn't. I am running windows XP home edition. Thanks!!Also, something that I think is proba bly related to me replacing my motherboard, when I restart my computer the time is not correct. It remembers what the date is, but the time is not correct. I have to change it every time i start the computer. Quote Link to comment Share on other sites More sharing options...
