Issues with mouse clicking
Hi all,
So, I'm having this issue with my mouse. It's kind of hard to explain, but pretty much, whenever I want to highlight a word, the word does not stay highlighted. For instance, I will highlight a word, but as soon as I let go of the Left-click button, the highlighting goes away. I'll have to do it numerous times before I can actually keep the word highlighted. Also, occasionally, when I want to click on something like say, the "File" option at the top of a web page, the box drops down, but only for a second. I have to click "File" several times before the drop-down box actually stays down.
Hopefully that makes sense. Is this a problem with my mouse? Or is there some option I can change to fix this? I don't have any other mouses to test.
Thanks for any help.
Welcome to the Windows Forum.
Is that something that suddenly started, or did it always behave like that?
Also, what mouse is it - standard mouse, or specific mouse with its own device driver (check Device Manager)?
If it is a mouse with its own driver, then perhaps updating to the latest driver version may help. But I suspect that it is a hardware problem - that the click-release somehow triggers another down-click (or something).
Can you try an alternate selection method: place the cursor on the left side of the text you want to highlight, hold the Shift key down, then click at the end of the text - does that work?
It kind of suddenly started, within the past month or so.
The mouse is a Dell laser mouse (without the rolling ball).
There are no drivers associated with the mouse.
Yes, your Shift key technique does still work.
I'm thinking it's a problem with the actual hardware/mouse. It was relatively inexpensive, so I don't mind buying a new one. I guess I just want to be sure that it's a problem with the mouse. Also, I would not want to have any issues again in the future (assuming I buy the same Dell mouse, because I do actually like it).
Thanks for the suggestions, though!
Yes, it's probably the easiest to get a new mouse. You may not be able to get a DELL mouse, as they are sometines strange when it comes to external hardware replacement. I remember trying to get a new DELL keyboard a while ago, and they insisted that they cannot sell me a DELL keyboard alone. At the end they (DELL) ordered a Microsoft keyboard for me... :blink:
i agree with that. Its better to buy a new mouse, im sure that there is a problem with the sensor. no point of repairing it :rolleyes:
