Autorun.exe has encountered a problem sorry for inconvinence close the
when I am trying to open the mercury mother board cd to install drivers I was getting this msg displayed
"only a part of a read process memory/write process memory request was completed".
Also I Autorun.exe has encountered a problem sorry for inconvinence close the application otherwise u may loose data contact Microsoft can u plz tel me what's the problem and how to fix this problem.
  • 3 weeks later...
Which version of Windows are you running there? The first thing for most to do upon finishing up a fresh install of Windows is to go into the Control Panel>Auto Play section to set software/games installers to the install setting Others can be set to "take no action". When placing the motherboard or any other software disk in the drive the autorun.inf, setup.exe, install.exe, or launcher.exe main file will then load on it's own.
For board drivers and utilities the manufacturer's support will have those there as well as newer updates available. Once downloaded to a folder you can usually run the installer or browse to the folder itself to see an update or extra item installed.
