2008Srv DNS and Active Directory Issues
Hi, I hope someone can help me with this issue:
I have a small network with 15 clients, 1 Win2008server, 1 ZyWall USG-100 firewall, two 10/100 switches and one wireless.
At first the network ran the WAN through the server, which had an internal and external ethernet port set up. When I introduced the firewall to the network, I connected this to the WAN, and then connected the server directly to the firewall. The two switches then connect all the clients to the server through the firewall.
I had planned to give the Zywall control of DHCP and DNS functions, to offload some functions of the server, as it was pressed. I did not think this through though, as the Active Directory needs these functions to control the network. I realised this and reinstalled the DHCP and DNS functions on the server, but it seems that something is missing.
I have got the internet up and running, all clients are on the domain and use automatic IP, and they have the server IP as DHCP and DNS. They have the firewall address as gateway. So the internet runs fine, and clients can log on to the network and they can access their folders.
The problems are:
1. They have extremely long log on times
2. If they try to print from a printer connected through the server they freeze.
3. Application of group policies work at times and other times not.
I have tried taking a computer off the domain and putting it back on, and I got an error message that read something like: "A domain controller for the domain could not be contacted.". I restart the machine and it seems to be on the domain.
I have checked the connection to the server by pinging its name, its ip adress and i have pinged the domain name. They all answer quite fast, so it seems the problem must be internal in the server. I am thinking that the removal and reinstall of the DHCP and DNS services have created some disconnect with the Active Directory on the server, but I have yet to find a way to fix it.
All suggestions are welcome :)
