Mebendazol Posted May 9, 2010 Report Share Posted May 9, 2010 XP Professional SP3 don't assign letter to removable USB drive, though:- it's properly detected and hardware works normally (changing ports or flash drives gives no result, on other PCs flash drives operate normally),- I have no network or external drives, so I found no precedent on microsoft.comThis problem began when I repaired current XP installation with setup.I can assign a letter to removable USB through disk management. Then I browse flash drive with Total Commander (explorer this way has a setback - it can write on the flash drives only files/folders with dos-names)But such rigmarole is inconvenient, so I would be greatful if someone can advise me a way to fix this without reinstalling XP. Quote Link to comment Share on other sites More sharing options...
Mebendazol Posted May 16, 2010 Author Report Share Posted May 16, 2010 Problem solved. It was caused by ScsiPassThrough-driver (SPTD) installed with Daemon Tools. It went wrong after repairing XP. Details in this forum Quote Link to comment Share on other sites More sharing options...
