hp1990 Posted June 5, 2010 Report Share Posted June 5, 2010 Hey guys. this is the situation :1. i was using vista and modem/router model is 2Wire 2700HGV-22. when i used the above system, i did portforward successfully just by following the instructions on portforward.com3. then, i did a clean installation of windows7 professional on my cpu. 4. after installation, i tried to portforward again, but this time couldn't. i checked the cmd thing-y which was adviced to alot of people whom had similar difficulties, and my modem is using single NAT, static ip checked blabla...5. even my laptop, which i also done portforwarding previously(becos i used this same connection for my laptop too) could not do the speed test guide on utorrent successfully. 6. i dled the portforward check with the free program provided by portforward.com, and results i get were always "Could not connect to portforward.com server" something like that.Things to note : will having windows.old folder affect operations on my pc? no right?? and my modem has wireless capabilities, thats how my laptop connects.ports which i am forwarding for pc and laptop are 31865 and 22302 respectively.thanks in advance! i urgently need this up because of school work (softwares etc)if there is any need of screenshots pls do tell me :) Quote Link to comment Share on other sites More sharing options...
hp1990 Posted June 5, 2010 Author Report Share Posted June 5, 2010 help pls! :( Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted June 6, 2010 Report Share Posted June 6, 2010 It is possible that somebody here may have some answers for you, if you are patient. But wouldn't it be better if you went directly to http://forum.portforward.com/? Quote Link to comment Share on other sites More sharing options...
