goblin1 Posted June 8, 2010 Report Share Posted June 8, 2010 Hi,Is there really much benefit to connecting via Wireless-N as opposed to Wireless-G? Will I notice the difference? I'm on a 10mbit connection, with a Draft-N router, but my desktop isn't Draft N-compatible, but.. I'm not sure if I'd see much of a difference if it was. Online gaming is my thing; I think the speeds and lag I get are at acceptable levels, but I've been told switching to draft-N will make things even better. I'm considering http://www.cisco-routers.co.uk/u/pd/nwd170...5159001b/771397 .. any thoughts?Apologies if I'm posting in the wrong section, I'm a newbie :)Thanks in advance! Quote Link to comment Share on other sites More sharing options...
goblin1 Posted June 11, 2010 Author Report Share Posted June 11, 2010 I've been told this - http://ramblax.co.uk/p~p-96172624~Linksys-WMP600N-WiFi-80211-N-Dual-Band-PCI-Card-4260039348245.aspx - would be better suited to a desktop - any thoughts? Quote Link to comment Share on other sites More sharing options...
Syndrose Posted September 10, 2010 Report Share Posted September 10, 2010 If all you are using it for is online gaming, then Wireless B is ok.Most internet connections are around 1Mbps (and thats peak, not constant) Wireless G can go up to 54Mbps. So you do the math, its pretty easy.Whoever told you that Wireless N will improve it, is just trying to sell you something. Quote Link to comment Share on other sites More sharing options...
