Technext Posted July 22, 2010 Report Share Posted July 22, 2010 Hi,I am trying to connect to a remote server using Plink tool. Both my local and remote machines are Windows. On remote server, I have OpenSSH server installed. I am able to run commands on remote machine but there is some problem with long UNC path, which I noticed today.For example,--------------------------------------------------------------Working:Plink -ssh -pw xxx user@server cmd.exe /c copy //test//somedir//inside//some.exe //test//another//Not Working:Plink -ssh -pw xxx user@server cmd.exe /c copy //test//somedir//inside//more//prog.exe //test//another//When I did echo to see how it's interpreting the command, I saw the following output:.....//test//somedir//inside//mo //test//another//As you can see above, it's not working if the sub-directory level increases above 2. It just prints the first two characters of the third directory (here 'mo' for directory name 'more').--------------------------------------------------------------This doesn't look like the 8-character DOS issue because the real path that I am using has the first directory containing 11 characters. I am not sure whether it's a limitation of Plink tool or command shell or something else.By the way, my script takes the UNC path as input from the user. It can contain any no. of sub-directory levels. I think it should not exceed more than 8-9 levels in any normal case but it'll be better if the solution works for any arbitrary levels.I have thought of mapping the UNC path to some drive letter but I want to explore some other alternative (short & sweet). I think, implementing mapping might involve a good deal of work.Can anyone suggest a way to overcome this problem?Thanks,GC Quote Link to comment Share on other sites More sharing options...
Technext Posted July 25, 2010 Author Report Share Posted July 25, 2010 I was trying to see whether mapping the UNC path to a drive letter on the same machine (where UNC is pointing to) works. I tried using SUBST command for the same, but to no avail. I do not get any error message after I execute the command but when I check the remote server, I am not able to see the virtual drive that I assigned to the UNC path.plink -ssh -pw xxx admin@server cmd.exe /c subst v: '\\\server\use'[ignore the triple slashes; they work with Plink.]I also tried using the actual path, but again it did not work.plink -ssh -pw xxx admin@server cmd.exe /c subst v: 'H:\use'After I run the above command, I cannot see v: drive on the server.Any pointers/help?Regards,GC Quote Link to comment Share on other sites More sharing options...
