Guest ellas Posted September 13, 2003 Report Share Posted September 13, 2003 Establishes what video codecs (audio and video) are required to play an AVI file. Determines whether these codecs are installed on your system. Isolates problems associated with these codecs. Simple operation - Basic use: "File > Open", then read results -------------------------------------------------------------------------------- Identifies download induced problems (truncated files, "cooked" files, etc.) Shows framerate, duration, aspect ratio, bitrates, AVI structure info, and more. Displays and allows editing of RIFF info (title, etc); displays "hidden" ASCII info. -------------------------------------------------------------------------------- Drag and Drop and "Send To" support, multi-file (batch) processing support Copy/Paste or text export GSpot information - format is user configurable. Built-in database of 350 video and 150 audio codec types Advanced UI including "dual-mode" and hyperlinked "persistent" tool tips -------------------------------------------------------------------------------- Full support for OGG media files as well as AVI stream formats Identification (only) of non-AVI files (.mpg, .mov, .qt, .rm, .swf, .wmv, .asf, etc.) Supports VFW, ACM, DirectShow and DMO codec types (audio and video) -------------------------------------------------------------------------------- Win95/98/ME/NT/2K/XP No Install (optional), No spyware, No advertising, No registration Free http://www.headbands.com/gspot/ Quote Link to comment Share on other sites More sharing options...
