How to run a script after connecting to a wireless network
Sandman01
Hello, I am trying to figure out how I can run a script, whether it be a shell script or powershell script, after I connect to a wireless network. Using the group policy editor and adding a logon script before boot would not work. This task is pretty simple in linux using wicd as a daemon, however my spouse is running Windows 7 and I can't seem to find support for this anywhere. Any help would be appreciated.
After browsing through all of the control panel, I have found a way to do what I wanted to do. You have to use the task scheduler to do this. You must create a schedule with the Trigger of "Microsoft-Windows-NetworkProfile/Operational" and under conditions check the box that says "Start only if the following network connection is available. I hope that this helps you guys out there, as it did me. Sorry for posting when I should have just spent more time browsing.
  • 1 year later...
Thank you very much. This helped me. You're a genius!
