skymac Posted October 7, 2010 Report Share Posted October 7, 2010 Question: Is is possible to take a incoming WiFi connection, say over a laptop and then push that connection to the internet thru your ethernet to the incoming side of a router, where the router can then push out the signal? Basically what I'm trying to do is setup a wireless on wireless ad-hoc network. My incoming connection is not wired, its wireless. So will I be able to do that some how? Or second, what If I had a external USB wireless adapter? Could I use that to recieve the internet signal then create a ad-hoc wireless network and use my internal card to support that network, while the external usb adapter supports the main line network?Thanks,Justin Quote Link to comment Share on other sites More sharing options...
