moon Posted September 17, 2003 Report Share Posted September 17, 2003 Is anybody proficient with Macromedia Flash MX and willing to post a few pointers ? I've got a sort of aversion to clicking on 'Help' tabs. :blink: Quote Link to comment Share on other sites More sharing options...
Guest Travis86 Posted September 18, 2003 Report Share Posted September 18, 2003 Um, you should do as much research on a subject as you can before you post something, and once you post something you should give a specific question. But none the less:When I have a Flash problem, I usually refer to the Reference panel, which gives easy-to-understand help. If you can't find anyone to answer you on this forum, you can try FlashMove.com, which is a dedicated Flash forum. Quote Link to comment Share on other sites More sharing options...
moon Posted September 18, 2003 Author Report Share Posted September 18, 2003 Sorry, travis. I sometimes think that everybody reads all the boards here but , of course, that's a wrong assumption.http://www.windowsforum.org/support/forum/...?showtopic=4678Thanks for the pointer though. Quote Link to comment Share on other sites More sharing options...
