ap1 Posted December 9, 2010 Report Share Posted December 9, 2010 One pc has xp media edition. Other has xp home edition. I can not get wireless peer to peer to work. Quote Link to comment Share on other sites More sharing options...
ap1 Posted December 9, 2010 Author Report Share Posted December 9, 2010 # 1 pc has xp home edition. # 2 pc has xp media edition. #2 pc is connected to the net through a hub then a router.problem 1:sometimes I can access folders but not the net.problem 2:sometimes I can access the net but not the foldersproblem 3:sometimes I can not access anything.I use pc 1 as the client and pc 2 as the server. Quote Link to comment Share on other sites More sharing options...
Rapid Sphare Posted December 31, 2010 Report Share Posted December 31, 2010 To use wireless networking, you need a wireless networking card and to configure the kernel with the appropriate wireless networking support. The latter is separated into multiple modules so that you only need to configure the software you are actually going to use. Quote Link to comment Share on other sites More sharing options...
