Pin GodMode To TaskBar
Makcalable
(This particular tip is for Windows 7)
Ok we all know how to access the hidden God Mode, And not everyone know how to add this to the taskbar, but this will show you how to pin God Mode shortcut to Windows 7 Taskbar so that you can quickly and easily access it.
Follow these simple steps:
First you will need to create a new shortcut. To do this, right click on your Desktop and select New Shortcut;
It will launch Create Shortcut wizard as snapshot above, Now enter following string in location box;
explorer shell:::{ED7BA470-8E54-465E-825C-99712043E01C}
Click on Next button, Now type GodMode in name box and click on Finish button, It will then create a new shortcut on your Desktop.
Now, to change the icon, Right-click on the shortcut and select Properties, Click on Change Icon button, Type control.exe in text box and press Enter, Select the Control panel icon, click on OK button and then Apply the changes.
Now you just need to pin this new shortcut to Taskbar, You can either drag & drop the shortcut to Taskbar or right-click on the shortcut and select Pin to Taskbar option.
Hope you found this useful! ;)
(sorry if already been posted)
  • 2 weeks later...
