Makcalable Posted December 24, 2010 Report Share Posted December 24, 2010 If you are struggling to find out what screen resolution you currently have CLICK HERE TO SEEOrOpen Display Settings by clicking the Start button > Control Panel > under Appearance and Personalization click on Adjust Screen Resolution;OrJust right click your desktop on an empty space and select Screen Resolution :)Control Panel Window Below;Screen Resolution Window Below;Use the first option to check the size of your screen resolution and use the second to check the size and or adjust your screen resolution.I hope this helps you with your screen resolution! ;) Quote Link to comment Share on other sites More sharing options...
