How To Speed Up Menu Show Delay
Makcalable
(Always backup your registry when performing these sorts of tasks)
Menu Show Delay to slow for you. then why not speed it up??
(This Works On XP - Vista - Windows 7)
1. Open the Start Menu - then type regedit in the search box and press Enter.
2. In regedit, navigate to - HKEY_CURRENT_USER\Control Panel\desktop
3. In the right pane, right click on MenuShowDelay and click on Modify.
4. Type in a number between 0 to 4000 - for how many milliseconds you want the Menu to wait before it opens, the lower the number, the faster the response time. It is not recommended you use 0 as it will be difficult to navigate through at that speed, So use 1
5. Click on OK to apply.
6. Close regedit.
7. Then all you do is restart the computer to apply these changes.
Now you will see a big difference!
Hope you found this useful! ;)
