Snbaeeqa Posted July 18, 2011 Report Share Posted July 18, 2011 System: XP pro SP3I am having a weird XP issue where the driver for a printer is in the "C:\WINDOWS\system32\DRVSTORE" location, shows up in the driver list when manually searching but, I can not get a script to install the printer.If I manually install the printer (using the driver from the list) it works. If I then remove the printer and run the script again. It will add the printers correctly. But, I am trying to automate the install process for over 100 computers.thanks Quote Link to comment Share on other sites More sharing options...
