cd-rw disk problems
Did you burn that disk with Nero? If so, Nero probably did not "close" the disk. Nero has a bad habit of defaulting to leaving the disk open, so more files can be added to it later. You can view the files on the un-closed disk by using THE SAME VERSION of Nero, that you used to burn the disk initially. I have tried to use a different version of Nero, to view the files on an un-closed disc. Never could get that to work. Always had to be the SAME VERSION as burned the disc.
