miseryguts Posted October 13, 2011 Report Share Posted October 13, 2011 So i'm trying to run an application and get a Unhandled exception error: Access to the path C\Windows\SysWOW64\user32dll.old is denied. I have the app set to use full control & am running it as administrator, what is the problem & how can i fix it..? Thanks. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted October 13, 2011 Report Share Posted October 13, 2011 user32dll.old is obviously not a standard module; does it exist on you system? Does it belong to that application? Quote Link to comment Share on other sites More sharing options...
Makcalable Posted October 13, 2011 Report Share Posted October 13, 2011 Have you tried running a System File Check? From elevated command prompt type in sfc /scannow Hit Enter and let it scan and see what it picks up and fixes, then type Exit then press Enter. Quote Link to comment Share on other sites More sharing options...
