elguapo1991 Posted February 21, 2012 Report Share Posted February 21, 2012 I'm running Windows 7 Home Premium 64-bit on a Dell XPS M1330 This is exactly what happened: My computer was working fine/normally. I restarted my computer to get to the BIOS settings (I was helping a friend of mine set his Boot priority and I needed a reference) I missed the window of time where I could press F12 so I restarted my computer again. I went into BIOS settings, changed nothing, exited, then logged in to windows. After logging in, windows seems to start up normally for a couple minutes, but then everything freezes. I can still move my mouse, but the windows loading cursor appears over everything. This stays frozen indefinitly. I restarted and booted in safemode. I ran MalwareBytes, Sbybot: S&D, AVG Virus Scan, and I defragged my computer. I also uninstalled extra programs and disabled most non-neccesary startup services and programs in MsConfig. Tried re-starting again. Same freezing happened. Restarted in safemode, scheduled ChkDsk. Restarted again. ChkDsk froze at 98% at step 5 (after about 12 hours). Had to power down and start up. Ran ChkDsk in command prompt in safemode. Every time I run ChkDsk in command prompt, I get this message at the end: Usn Journal verification completed.The Volume Bitmap is incorrect.Windows found problems with the file system.Run CHKDSK with the /F (fix) option to correct these. I run chkdsk /f, then schedule it to run at startup. ChkDsk runs at startup, completes within 10 mintutes. But I still can't log in if I'm not in safemode, and if I run chkdsk in command prompt, I still get the same message everytime. I've also tried running startup repair both from the HDD and from my repair disc. Neither detected or fixed a problem. I have also run sfc /scannow in commmand prompt a couple times. It fixed nothing. *** Should I start shopping for a new laptop or is this fixable? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted February 22, 2012 Report Share Posted February 22, 2012 Do you have a backup of all your data? If not, make one (in Safe Mode) as soon as possible. Next schedule a chkdskchkdsk /f /r /v /xThis will again run for several hours; perhaps run it overnight. If that does not fix the error, try to format your HD and reinstall Windows. Use the backup to restore your data. Quote Link to comment Share on other sites More sharing options...
