haja Posted September 23, 2012 Report Share Posted September 23, 2012 I did install Win7 on a HD configured as IDE. I now purchased an SSD which has pretty bad performance with IDE (even booting takes forever). Therefore, I switched to AHCI but now when I try to start the system I always get "Startup Repair Your computer was unable to start. Startup Repair is checking your system for problems...". I have backups of the original system both made with Windows Backup and EaseUS Todo Backup. How can I get this to work on my SSD & AHCI without having to reinstall the OS and programs? Quote Link to comment Share on other sites More sharing options...
Rubenv Posted November 27, 2012 Report Share Posted November 27, 2012 probably reinstal , had the same when i bought my ssd and switched, after instal it was fine , just make a backup on the HD for your files and programs, (make a backup partition) and delete the windows partition ( or keep if you are paranoid) and instal windows on the SSD and change the startup device to the SSD Quote Link to comment Share on other sites More sharing options...
