UKAspie Posted January 12, 2013 Report Share Posted January 12, 2013 I have an XP-64 system that keeps blue-screening.I can't read the minidumps with dumpchk or windbg. Is this because they are 32 bit programs? If so, are there 64 bit versions available?The Microsoft advice to roll back a software change isn't much use - how many Windows Updates should I roll back? Quote Link to comment Share on other sites More sharing options...
UKAspie Posted January 13, 2013 Author Report Share Posted January 13, 2013 p.s. I have Visual Studio - that might be a better option if I knew how to crack a dump in it. Or alternatively I have some experience with windbg. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted January 14, 2013 Report Share Posted January 14, 2013 There shouldn't be a problem reading dumps on a 64-bit system. What exactly means "can't"? Quote Link to comment Share on other sites More sharing options...
UKAspie Posted January 14, 2013 Author Report Share Posted January 14, 2013 Sorry - I didn't give enough details.Dumpchk says:Loading Dump File [C:\WINDOWS\Minidump\Mini122812-01.dmp]Mini Kernel Dump does not contain enough information to be debuggedCould not open dump file [WINDOWS\Minidump\Mini122812-01.dmp], HRESULT 0x80004005 "Unspecified error"**** DebugClient cannot open DumpFile - error 80004005Windbg says:Could not create process 'WINDOWS\Minidump\Mini133812-01.dmp', Win32 error 0n193%1 is not a valid Win32 application.Visual Studio opens a file that starts:PAGEDU64 Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted January 15, 2013 Report Share Posted January 15, 2013 Where is your Windbg.exe actually located?I find mine at C:\Program Files\Debugging Tools for Windows (x64) - so it's a 64-bit application.Unfortunately I do not have any minidumps on my system, so I can't test it.Can you zip up your minidump and attach it to your next post? Quote Link to comment Share on other sites More sharing options...
UKAspie Posted January 16, 2013 Author Report Share Posted January 16, 2013 Thanks for your reply. That's where my copy of windbg is too. I've attached a zip - I think ...Mini122812-01.zip Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted January 23, 2013 Report Share Posted January 23, 2013 Sorry for not replying; I have been a bit more busy than usual.I will try to take a look at your dump today. Quote Link to comment Share on other sites More sharing options...
UKAspie Posted January 31, 2013 Author Report Share Posted January 31, 2013 I have dmpchk and windbg. I also have Visual Studio 2008.If any of these can be used to analyse the dumps I would be happy to do the work myself.Alternatively if the dump I submitted really is unreadable I would appreciate any suggestions for getting a readable one. Quote Link to comment Share on other sites More sharing options...
