What Will Your Next Pc Be?
Guest PC Eejit
Madboy, while you're still deciding, I'd recommend you start by choosing the motherboard.
When you've chosen one with 'zillions' of slots, check which CPU will fit and which memory.
Have a look at the Asus site and a few others.
I always remember when I got my first PC, I planned to go for a fast CPU and lower memory but was told 'What's the point of having an E type Jag with a one gallon petrol tank'.
Basically if you are on a budget it would be better to have say a 1.7Gig with 512 meg memory than a 2.1 with 256 memory. If you've chosen a board which will take a higher memory you can always upgrade the CPU at a later date. Check the prices to see the difference.
My next PC will be something along the lines of this...
MBEPOX4T4AP Epox 4T4A+ (Skt 478) £103.57
HDDIWD2000JB 200Gb W/Digital WD2000JB £210.93
CPUINTP4G26R533 2.6Ghz Intel P4 Retail (Skt 478 533Mhz FSB) £214.50
RAMBUSA5 256Mb Rambus (PC1066) x2 £128.70
COOLGBLCAK38 Global Win CAKII38 (Skt A / Skt 370) £25.79
VGAGWDGF4TI4600 128Mb Gainward Geforce4 Ultra/750 £199.10
FDDA1 3.5 Floppy Disk Drive 1.44Mb £6.56
SNDSBAUDPLT2 Sound Blaster Audigy Platinum 2 £128.15
CDRPIODVRA05 Pioneer DVR-A05 DVD-RW Drive Retail £204.05
CDRAOP56RTL 56x Aopen CDROM Retail £14.25
COMMIEEEA1 Firewire 3-port Host Adaptor £14.30
CASEFLWSF201TB Transparent Aluminium Case £129.38
SPKCTINSP5700 Creative Inspire 5.1 5700 £177.06
MONIIYP0A 18.1" Iiyama LCD AS4636D £605.00
Subtotal £2,161.34
VAT £378.23
Total £2,539.57
(well thats my ideal computer!)
Guest Timeforabeer
Well..I built this one about 2 months ago...
AMD 2000+
Epox 8K5A2+ (RAID)
512k DDR 2700 RAM
5 bay tower with 350w psu
LG 40x12x40 cdrw
LG 16xDVD
2 x 20Gb Maxtor D740X 7200rpm (mirrored on the RAID)
2 x Seagate Barracuda 60Gb Disks
PNY MX 440 64Mb DDR video card
all for just over £400.00
Some bits from old system ,but mainly new
Guest Nellie2
My next one will probably be self build. Built my present one but it is a bit old hat now but ok for what I use it for.
I would choose my processor first then the motherboard....as good as I could afford and then all the other bits from there.
In my experience, putting it together isn't the hard bit......it is figuring out why it won't work when you switch it on!!!!!!
:blink:
