Ammar Posted June 5, 2013 Report Share Posted June 5, 2013 I want to install QuickBooks 13 on my system with 1GB ram stick installed, the minimum requirement for QuickBooks 13 is 1GB. Now when I run the setup it says "you have 980MB ram, the minimum requirement is 1 GB" this might be becuse I have some shared memory with the graphic adaptor as I am not going to install a new stick of ram in near future, I was wondering if someone could help in to manupulate the code of the setup so it either does'nt check the ram requirement during installaion or change the registry etc of my system to tell the QuickBooks 13 setup that the system has 1 GB ram or by telling me of any other way to install the system. I am waiting for a fast response, plz hlp. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted June 5, 2013 Report Share Posted June 5, 2013 Not sure if this is easily done; perhaps you find a good answer at http://community.intuit.com/quickbooks Quote Link to comment Share on other sites More sharing options...
