Allstar Posted November 2, 2003 Report Share Posted November 2, 2003 Hi I am interested in purchasing a program which will help me to design the layout of my new home. I have found IMSI FLOORPLAN 3D HOME DESIGN SUITE V8.0 from PCWorld and wondered if Forum members have any comments or other suggestions. Regards Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted November 2, 2003 Report Share Posted November 2, 2003 I have never tried anything like that but I did a search using google and the keywords;home design software forum (I put forum in there because I am a great believer in forums and you may need some help or nudging in the right direction if you have never used anything like this)Anyway, there was quite a bit of choice.. give it a go and see what you come up with!! :) Quote Link to comment Share on other sites More sharing options...
Adwanoc Posted December 1, 2003 Report Share Posted December 1, 2003 It depends on what you need. If you need a very basic program for personal use, try this page. http://www.myfamilysoftware.com/clearencesales.html . Those little programs will cost around 50 bucks or so, and if you hurry you can get some on sale. On the other hand, some expensive Architecture programs can cost hundreds. Definatley be careful! Quote Link to comment Share on other sites More sharing options...
