damsio Posted November 17, 2021 Report Share Posted November 17, 2021 Hi all I put all my money to develop a website for virtual assistants in France. Unfortunately I do not manage to index in in Google anymore, due to technical issues I suppose. My developers do not seem to understand where the issue comes from. Does someone understand what's going on with Google? Thanks all Quote Link to comment Share on other sites More sharing options...
michalenkolorri Posted May 4 Report Share Posted May 4 It's weird that someone can't handle the site slowing down. This problem is very easy to solve in several ways. Quote Link to comment Share on other sites More sharing options...
CarolMoors Posted May 5 Report Share Posted May 5 Maybe you should end your partnership with these incompetent designers and find another company. I think the staff at the cheap web design company I worked with last year might be able to help you. Quote Link to comment Share on other sites More sharing options...
CarolMoors Posted May 11 Report Share Posted May 11 On 5/5/2022 at 3:40 PM, CarolMoors said: Maybe you should end your partnership with these incompetent designers and find another company. I think the staff at the cheap web design company I worked with last year might be able to help you. I can send you the contacts of that company if you need them. If your site is constantly lagging and the simplest check sites for errors lead you to more than ten bugs, you should think about changing designers. Probably, these people aren't doing their job right. Are you noticing errors only on your main version of the site or on the mobile version too? What platformer was your website built on? I'm curious to know what those web designers are failing with. Quote Link to comment Share on other sites More sharing options...
pewpewmarc Posted 9 hours ago Report Share Posted 9 hours ago I Checked your website to see if it's still lagging. Well, your website seems fine now, the page loads immediately. If this kind of issue happens again, the reason might be an excessive overhead on your website's database. To optimize your database it will be helpful if you remove it. Another problem could be because of some sort of caching issue that's preventing optimized page loading. Quote Link to comment Share on other sites More sharing options...
