Guest nellie2 Posted November 26, 2003 Report Share Posted November 26, 2003 FreeRAM XP Pro is a freeware application to free and defragment your computer’s RAM (Random Access Memory). As you use your computer, open applications, surf the Internet, and navigate Windows, your system’s memory will usually decrease because some software do not use memory correctly or do not return all of it after it is done using it. FreeRAM XP Pro frees up this memory, thereby increasing system response time, stability, speed, and efficiency. As a result, FreeRAM XP Pro is recommended for almost anyone, from low memory systems to high memory systems, from home office users to MP3ers to 3-D gamers.Don't be fooled by the name... it is suitable for W95 onwards!! :thumbup: FreeRam XP Pro Quote Link to comment Share on other sites More sharing options...
