MaxSam322 Posted April 21, 2023 Report Share Posted April 21, 2023 Hi Guys It seems that when I use online conference applications like Zoom and Teams my audio device is not working properly. But until last week it worked very well. Frequently the other party cannot hear what I say clearly and sometimes they can’t hear me at all. But when I use those applications through my smartphone the audio seems to work even with the same headset. I searched on the internet about this and found some guidelines for that https://techgizmore.com/fix-microphone-problems-in-windows-10/ . But the issue remains. Before last week all the applications worked very well for me. I cannot find the reason for this happening suddenly but I need to fix it soon because my work is based on these applications. (I am planning to take this laptop to a repair station) · I tried to use different headset devices to fix this issue but it remains as same. · Even if I had followed the guidelines given on the internet the issue cannot be solved (In some cases I cannot understand what they are referring to). I only use the above-mentioned applications for my work and I am planning to take my laptop to a repair shop. But I need to know if is there anything I can do to fix this without going to the repair station. (I have a Windows 10 operating system HP laptop, i7) Quote Link to comment Share on other sites More sharing options...
Maarklar Posted September 14, 2023 Report Share Posted September 14, 2023 Before the repair shop, update your audio drivers and check background apps. Also, test the microphone in other apps. Might save you a trip! Quote Link to comment Share on other sites More sharing options...
