devinmarco Posted April 24, 2023 Report Share Posted April 24, 2023 Hello everyone, I am currently facing some issues with blade servers and I was hoping someone in this forum could assist me. I have a UCS C200 M2 blade server and I am unable to access it. I have tried troubleshooting the issue but I am unable to find a solution. Has anyone else faced similar issues with blade servers? If so, could you please share your experience and how you resolved the issue? Additionally, I came across a post on this forum regarding search engine FAQs and tips. One of the tips mentioned was to use a "-" in front of the word you want to exclude from the search. This could be useful when searching for keywords related to blade servers, as some keywords may be very common and overload the server. Thank you in advance for your help and suggestions. Quote Link to comment Share on other sites More sharing options...
Maarklar Posted September 14, 2023 Report Share Posted September 14, 2023 Blade server issues can be tricky. Start by checking physical connections, then the management interface. If no luck, consider checking logs or reaching out to the manufacturer's support. Regarding the search tip, using "-" is indeed handy to narrow down search results. Hope this helps! Quote Link to comment Share on other sites More sharing options...
Engiepo Posted January 5 Report Share Posted January 5 On 12/27/2023 at 3:13 PM, allcode said: As for using NVMe M.2 SSD, it can really improve the performance and reliability of the server blade. NVMe SSDs are known for their durability and strong endurance, making them more reliable for demanding server workloads. Quote Link to comment Share on other sites More sharing options...
