mas2ala Posted June 15 Report Share Posted June 15 i hope you are doing well my website (https://www.mas2ala.com/) based on blogger, do i will face any problem to reach a strong seo, or maybe other platform better Quote Link to comment Share on other sites More sharing options...
dejko55 Posted June 24 Report Share Posted June 24 No, everything is the same. Try Wordpress, maybe. Quote Link to comment Share on other sites More sharing options...
Maarklar Posted September 14 Report Share Posted September 14 Great to hear you're diving into the world of SEO! Blogger is a decent platform to start, but it's worth noting that platforms like WordPress often offer more SEO flexibility and customization options. That said, Blogger can still be optimized for good SEO, so don't worry too much! To get a grip on how well your site is currently optimized, you might want to consider running an SEO audit. One tool that can be really helpful for this is free seo spider. It will crawl your website and provide you with detailed reports on errors, redirects, broken links, and much more. The insights you gain from the audit can guide you on what needs to be changed or improved for better SEO performance. Quote Link to comment Share on other sites More sharing options...
