monkey Posted January 12, 2004 Report Share Posted January 12, 2004 hello all it me monkey i need some help with a loptop my sisters boyfriend has given me to look at he has not told me when it hapend or and think i was just wondering if anyone knew a way to fix it its a Compaq Evo N1015v :unsure: and yes it looks like the matrix :D thanks monkey Quote Link to comment Share on other sites More sharing options...
monkey Posted January 12, 2004 Author Report Share Posted January 12, 2004 another Quote Link to comment Share on other sites More sharing options...
Sir Radfordin Posted January 12, 2004 Report Share Posted January 12, 2004 Looks like the screen itself is damaged or the cable between the mobo and the screen has worked its way loose. Wouldn't advise you try and fix it. Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted January 12, 2004 Report Share Posted January 12, 2004 no best get a new loptop :D Quote Link to comment Share on other sites More sharing options...
Sir Radfordin Posted January 12, 2004 Report Share Posted January 12, 2004 Cheaper option, tell your sister to get a new bloke and check his laptop works first ;) Quote Link to comment Share on other sites More sharing options...
monkey Posted January 14, 2004 Author Report Share Posted January 14, 2004 i just got quoted on a new screen they say £450 :( Quote Link to comment Share on other sites More sharing options...
Sir Radfordin Posted January 14, 2004 Report Share Posted January 14, 2004 It may not actually be the screen (though quite likely) so it may be worth seeing if you have a local shop that does laptop repairs and ask them to give you a quote. Quote Link to comment Share on other sites More sharing options...
monkey Posted January 14, 2004 Author Report Share Posted January 14, 2004 thats were i went and thats wat they said Quote Link to comment Share on other sites More sharing options...
