Guest Drovers Dog Posted January 25, 2004 Report Share Posted January 25, 2004 :P You know, I have had heaps of problems with my new Computer, Windows XP installed faulty, had a HDD fry, a Video Card fry, and eventually think I have found the problem, faulty RAM, for the second Computor running!! I now know Lightning strikes twice!!I just want to say to Nellie, it is not your fault, Love!! You, as we all know would not hurt a fly, you can't afford to, they might gang up on you, while you are flying to work, after all a couple of million of them on your wings would really muck things up!!! :whistling: :innocent: :D{edit: Did a little bit of editing... but thanks for the sentiment :) } Quote Link to comment Share on other sites More sharing options...
