TERBOW Posted February 21, 2003 Report Share Posted February 21, 2003 windows xp..I'm having problems closing pages and web sites down using either the RED box with the white X or file and close,only closes after several attempts or have to use windows task manager to end task ,this only started happening today,have tried restore but makes no dif,any ideas please Link to comment Share on other sites More sharing options...
Guest ellas Posted February 21, 2003 Report Share Posted February 21, 2003 any more details TERBOW such as ISP,dial up b/b is it I/E6,presume you have deleted temp files,index dat file and restarted. Link to comment Share on other sites More sharing options...
TERBOW Posted February 21, 2003 Author Report Share Posted February 21, 2003 thanks for your reply ellas.yes i havedeleted temp files ,and today installed latest xp critical update "IE6 SP1"813951" But this was happening before then,i have just run bootvis and got bootvis message "(disk1/0 warning disk write caching is disabled" i dont know if this has a bearing,also having dificulties logging on to here.also i have removed all my mp3 files to the bin. Link to comment Share on other sites More sharing options...
Guest Timeforabeer Posted February 21, 2003 Report Share Posted February 21, 2003 TERBOW....Do the maximize and minimize buttons work? Link to comment Share on other sites More sharing options...
Guest ellas Posted February 21, 2003 Report Share Posted February 21, 2003 this is how to enable write caching http://support.microsoft.com/?kbid=259716 Link to comment Share on other sites More sharing options...
TERBOW Posted February 21, 2003 Author Report Share Posted February 21, 2003 timeforabeer,yes they both work,thank you for your reply.ellas ,i'm not sure if write caching enabling is the answer,can you elaborate please. Link to comment Share on other sites More sharing options...
Guest Timeforabeer Posted February 21, 2003 Report Share Posted February 21, 2003 TERBOW....I've done that upgrade also..i've found that i have to click on the same box a couple of times before it works and the same on certain links and url's.. :( I've asked a mate of mine (very clued up) to take a look at it...if he solves it ...i'll post a reply... Link to comment Share on other sites More sharing options...
Guest ellas Posted February 21, 2003 Report Share Posted February 21, 2003 not really TERBOW just read on the net bootvis does not work if write caching is not enabled,not really related to your I/E prob,by the way is it enabled. Link to comment Share on other sites More sharing options...
peter e Posted February 21, 2003 Report Share Posted February 21, 2003 TerbowI don't know what's causing the problem, but if I may suggest that you try to close a window by using the keyboard shortcut - hold down Ctrl and press W. Holding down Alt and pressing F4 is the keyboard shortcut for closing an application.Pete Link to comment Share on other sites More sharing options...
TERBOW Posted February 22, 2003 Author Report Share Posted February 22, 2003 peter e Thanks for your suggestion,but tried them withour success.cheers anyway .m8 Link to comment Share on other sites More sharing options...
Prince of Calcutta Posted February 22, 2003 Report Share Posted February 22, 2003 try going to task manager and look under running processes. sometimes even after i close a window i have 6 or 7 iexplore entries and this screws up the whole system . when i end process things go smoother. Link to comment Share on other sites More sharing options...
Guest ellas Posted February 22, 2003 Report Share Posted February 22, 2003 terbow not running under the name gerrycan at pca are you :D http://www.pcadvisor.co.uk/index.cfm?go=di...77787&forumid=1 Link to comment Share on other sites More sharing options...
Prince of Calcutta Posted February 22, 2003 Report Share Posted February 22, 2003 windows xp..I'm having problems closing pages and web sites down using either the RED box with the white X or file and close,only closes after several attempts or have to use windows task manager to end task ,this only started happening today,have tried restore but makes no dif,any ideas pleaseGerrycan Sat, 22.02.03 | 14:39 o/s windows xp,with all updates installed. I am having trouble closing down web pages using either /file-close /the [red box with the white x ]in the top right of the page/or keyboard shortcut -cntrl +w.the only way i can close the page is by cntrl alt del end task in task manager,I have tried sfc /scannow and using the windows xp disk but this will not help,as it keeps asking for the disk,progresses so far then asks for the disk again.I have tried posting the problem in m/soft, ..has anyone ever had this problem and knows the answer.please. :D Link to comment Share on other sites More sharing options...
