Guest ellas Posted March 27, 2004 Report Share Posted March 27, 2004 hi my sister has just bough a concord camera http://www.concordcam.com/support/faq/eyeq...40z_support.htm it needs no drivers and appears installed in xp but when she double clicks the removable disc icon its says the card needs formatting and the file system is raw,but in two computers its been tested in with xp double clicking the r/disc icon shows the pictures and the file system is fat,any ideas? its a celeron 2.0ghz puter with intel chipset and xp home,mobo AOPEN AX4BS-V and usb seems to working ok. Link to comment Share on other sites More sharing options...
Guest northamuk Posted March 27, 2004 Report Share Posted March 27, 2004 Best bet is to use a Card Reader. Link to comment Share on other sites More sharing options...
Guest ellas Posted March 27, 2004 Report Share Posted March 27, 2004 should not be necessary as it works perfectly on 2 other xp machines.closed due to lack of answers :P Link to comment Share on other sites More sharing options...
