Prince of Calcutta Posted February 24, 2003 Report Share Posted February 24, 2003 yet another post on cleaning :D does anyone have any tips on cleaning a lcd screen? i was quite horrified to see a friend of mine use a soapy rag :o Quote Link to comment Share on other sites More sharing options...
Craig Posted February 24, 2003 Report Share Posted February 24, 2003 I bought a tub of Safeway Baby Wipes for 60P to use!Lasted me a couple of years!Works well. Quote Link to comment Share on other sites More sharing options...
Prince of Calcutta Posted February 24, 2003 Author Report Share Posted February 24, 2003 cheers :D will pass on the tip ;) Quote Link to comment Share on other sites More sharing options...
Scarthy © ® ™ Posted February 24, 2003 Report Share Posted February 24, 2003 I don't have a TFT, but I do have some Dataform Anti-static screen cleaner. This was 'borrowed' from someone's work....They use it there to clean their TFT screens.I have recently bought some Stanger Monitor/Filter Screen Cleaner. This was £1.29 (I think) from Aldi for a 250ml pump spray. It looks like the Dataform stuff to me and has a laptop picture on the bottle. ;) Quote Link to comment Share on other sites More sharing options...
madboy33 Posted February 24, 2003 Report Share Posted February 24, 2003 Now folks i dont have a TFT eitherBut i thought TFT's were meant to be cleaned by a damp cloth onlyIf you put to much pressure on them it can also damage the screen madboy33 Quote Link to comment Share on other sites More sharing options...
Guest Damo Posted February 24, 2003 Report Share Posted February 24, 2003 yeah..i use a Damp cloth aswell.....Especially on my laptop screen, which is pretty thin, even the slightest bit of pressure moves the screen Quote Link to comment Share on other sites More sharing options...
Prince of Calcutta Posted February 25, 2003 Author Report Share Posted February 25, 2003 But i thought TFT's were meant to be cleaned by a damp cloth onlydamp yes, soaking wet no :o so should also be careful about not applying too much pressure ? Quote Link to comment Share on other sites More sharing options...
