Hurdy Posted May 23, 2004 Report Share Posted May 23, 2004 How do you turn off/disable this function in XP please?Drive me insane they do.Edit: Maybe they're not smart tags. They are those little boxes that follow the mouse pointer around. Quote Link to comment Share on other sites More sharing options...
Chris Posted May 23, 2004 Report Share Posted May 23, 2004 Mouse trails? Control Panel, Mouse...pop-up descriptions? Control Panel, Folder options, view, last option "show popup descriptions..." Quote Link to comment Share on other sites More sharing options...
Hurdy Posted May 23, 2004 Author Report Share Posted May 23, 2004 Pop-up descriptionsThank you powerless that's worked a treat for the folders. Can they turned off in IE i.e. (sic) in the favourites column? Quote Link to comment Share on other sites More sharing options...
