reaperjim Posted August 9, 2004 Report Share Posted August 9, 2004 I have downloaded a number of files of the type that - up until a few days ago - would normally show in WINRAR format, but for some reason they are now all showing as WinZip after they finish dowloading and NONE of them can be opened. This cant just be bad luck as it's happened to so many files that I have lost count. Does anyone know what the problem could be? The file size shows as the correct size, but only one file out of the whole spanned archive shows up when I check the contents of the compressed file. Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted August 9, 2004 Report Share Posted August 9, 2004 Open up winRAR.Options > Settings > Integrationcheck all that you want winRAR to open with.As an added check, you may also open up an explorer window (my computer)Tools > Folder Options > File Typescheck for .zip and make sure it is set to open with winRAR Quote Link to comment Share on other sites More sharing options...
Bling Posted September 16, 2004 Report Share Posted September 16, 2004 You can always right click and select the "Open With" option. Quote Link to comment Share on other sites More sharing options...
