Chris Posted September 12, 2004 Report Share Posted September 12, 2004 ShaderMark 2.1 is a DirectX 9.0 pixel shader benchmark. All pixel and vertex shader code is written in Microsoft’s High Level Shading Language. ShaderMark provides the possibility to use different compiler targets and advanced options. It also features a picture quality comparison based on mean square error (MSE) values.Currently there is no DirectX 9.0 HLSL pixel shader benchmark on the market. Futuremark's 3DMark03 (www.futuremark.com) and Massive's AquaMark 3.0 (www.aquamark.com) are bases on hand written assembler shaders or partly HLSL shaders. HLSL is the future of shader development! The HLSL shader compiler and its different profiles have to be tested and this gap fills ShaderMark v2.1. Driver cheating is also an issue. With ShaderMark, it is easily possible to change the underlying HLSL shader code which makes it impossible to “optimize” a driver for a certain shader, instead of the whole shader pipeline. ShaderMark v2.1 is also the first pixel shader benchmark, which measures the performance of the new shader model 3.0More | Here Quote Link to comment Share on other sites More sharing options...
