VoDsl Wont work after cisco Ata upgrade
leaaaa
i was reading an article on VoDsl and i saw this info saying the way to upgrade a cisco Ata (i have cisco ata186) and now i cant seem to get the vodsl to work it seems as if the router cannot find the ip of the ata. I would be grateful if anyone has any idea as to what to do or how to roll back the driver?
its not as easy as that you see the ata device is atached to the router and the upgrade has been done by inserting some numbers this is where i found that from http://www.iconnecthere.com/nonmembers/eng...es_ata.html#s31
somewhere here it says this Please follow the instructions below if you need to upgrade your software.
DO NOT unplug the ATA whilst upgrading.
1. Pick up the phone and press the button on the ATA. You will hear the prompt “Configuration
Menu.”
2. Press 1 0 0 # to access the upgrade menu.
3. Enter the following information into the phone exactly as listed: 213*137*73*159*8000#
4. After a short time (up to 5 minutes), you will hear the words “Upgrade Successful”.
5. Your software has been upgraded successfully. To read the software version again, press 123#.
If the upgrade fails, verify that your ATA is properly configured on your home network and check your ISP connectivity.
that is what i did
