If XP Installation Stops Responding
When you install Microsoft Windows XP, the installation process may stop responding, Setup may display an unrecoverable error message, or you may experience other problems that prevent Setup from completing successfully. Your only option is to restart your computer. This typically occurs during the last 30 minutes of installation, when devices are detected and drivers are installed.
If this happens to you, take a look here
