ltwlthr67 Posted October 13, 2004 Report Share Posted October 13, 2004 I'm running Windows Me and suddenly have a problem opening 'my pictures' file. A popup message declares 'Your current security settings prohibit ActiveX Controls on this page. As a result the page may not display correctly' and of course it doesn't. I'm not on line when this happens, it doesn't seem to have anything to do with the internet. I've enabled all activex on security settings and have disabled my Firewall, virus checker and popup stopper; none of that worked. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
-pops- Posted October 14, 2004 Report Share Posted October 14, 2004 As an initial thing, try updating ActivexTo update ActiveX add-onsOpen Internet Explorer. On the Tools menu, click Manage Add-ons. In the Show box, click the arrow and select Add-ons that have been used by Internet Explorer. In the list of add-ons, click the add-on you want to update, and then click Update ActiveX. Related Topics(From Windows Help and Support)Another section of XP Help & Support states:Be cautious about allowing Web sites to run scripts or ActiveX controls on your computer. While these items can enhance Web browsing, they can also be a security risk, and it’s best to avoid using them when you can. However, some Web sites or tasks might require them and you will have to decide whether to trust ActiveX controls that Internet Explorer blocks for your safety. Quote Link to comment Share on other sites More sharing options...
ltwlthr67 Posted October 20, 2004 Author Report Share Posted October 20, 2004 Pops, thanks. I should have waited for your reply. After reinstalling windows, Mypictrues works fine, but now I'll have to reinstall all the updates. Your solution would probably been much simpler. Thanks for responding. Next time I'll wait. :) Quote Link to comment Share on other sites More sharing options...
