Start Menu@Secondary Monitor
Right click the Desktop > Properties > Settings Tab
Look around at the settings and see if you can find the Extend Desktop onto secondary monitor. Click that, but also check advanced settings to make sure it is set to "mirror" the first monitor. This will give you the same image on both, rather than extending it across.
in actual fact that doesnt matter. right click on desktop-> properties-> settings there is an option in the middle of the screen that says "use this device as the primary monitor that will be checked so you have to click on the secondary monitor and check that as the primary monitor now if you go back to the previous monitor that option should be unchecked
